Discussion topic: Wifi
This message was authored by: Andy498
Wifi
Internet keeps dropping off over the last 7 days losing connection is there works in the area going on impacting this? Really poor WiFi at the minute
Re: Wifi
@Andy498
Re: Wifi
@Andy498 WiFi should not be affected by those conditions you mention, broadband loss is possible, see if the help shows you anything linked below.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
