Discussion topic: Wifi
Message posted on 14 Jan 2026 10:43 PM
Wifi
My wifi keeps freezing non stop even tho iv done the usual checks and the speed has been 152 every day . Called sky says there no issue but I have Cityfibre and supposed to be fast! Iv had nothing but trouble with it .... any ideas
Message posted on 15 Jan 2026 07:45 AM
Re: Wifi
@Andycareen1111 the speed to your hub thst Sky measures is somewhat different from the speed your devices can access overcWiFi. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
