Discussion topic: Wifi
Message posted on 08 Jan 2026 08:36 PM
Wifi
UHD often messes up. The tv and sound isn't synced up. I
Message posted on 08 Jan 2026 08:51 PM
Re: Wifi
@JimmyLee On what device? What broadband package are you using speed wise for the UHD connection!
Message posted on 08 Jan 2026 09:16 PM
Re: Wifi
Fibre 300. Using the sky puck (Sony tv). It'll often just say "wait for your programme to load" and then restart
Message posted on 08 Jan 2026 10:35 PM
Re: Wifi
@JimmyLee Would look on the sky Stream section for the puck and especially if everything else is going good for connection to the sky Hub you have and it's only a puck problem currently!
