Discussion topic: Wifi
Message posted on 07 Dec 2025 06:07 PM
Wifi
Message posted on 07 Dec 2025 06:08 PM
Re: Wifi
Is it between midnight and 0700?
If not, Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 07 Dec 2025 08:06 PM
Re: Wifi
It's always around 6 pm
Message posted on 07 Dec 2025 08:08 PM
Re: Wifi
So what happens with the troubleshooting above?
Message posted on 07 Dec 2025 08:10 PM
Re: Wifi
I tried that didn't work just saying everything is working fine
