Discussion topic: Wifi
Message posted on 21 Nov 2025 06:40 PM
Wifi
Message posted on 21 Nov 2025 06:56 PM
Re: Wifi
@Kayleighsparrow
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
