Discussion topic: Wifi
Message posted on 18 Nov 2025 07:41 PM
Wifi
Message posted on 18 Nov 2025 08:25 PM
Re: Wifi
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 18 Nov 2025 09:07 PM
Re: Wifi
I have sky max how do I get the pods??
Message posted on 18 Nov 2025 09:39 PM
Re: Wifi
@loopylad13 Having a sky Max hub does not give it to you as a automatic, do you have the additional sky Max subscription addon as well as the Hub? That cost is an additional £10/month on your bill, if you do then call sky and start your request with them!
Message posted on 18 Nov 2025 09:53 PM
Re: Wifi
I have the subscription so will give them a call tomorrow thanks
Message posted on 18 Nov 2025 09:58 PM
Re: Wifi
@loopylad13 Linked all the info, so have a read before you call them so you are aware off all the restrictions in getting!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
