Discussion topic: Weak connection
This message was authored by: JanR2
Weak connection
Something is not working properly.  I have one bar on my phone
Re: Weak connection
@JanR2
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Re: Weak connection
@JanR2 Did you ever have more, if you do suspect the hub, switch it off for 5 minutes then back on again then see if you get more indication on wi-fi bars!
