Discussion topic: Wifi
Message posted on 09 Nov 2025 10:43 AM
Wifi
Message posted on 09 Nov 2025 11:36 AM
Re: Wifi
@Sonya-
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
