Discussion topic: Wifi
Message posted on 03 Nov 2025 08:27 AM
Wifi
My wifi status is no internet but your checker says it's fine
Message posted on 03 Nov 2025 10:09 AM
Re: Wifi
@vlou252
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
