Discussion topic: Wifi
Message posted on 28 Oct 2025 05:01 PM
Wifi
WiFi is not working at all
Message posted on 28 Oct 2025 05:58 PM
Re: Wifi
@Jill71
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
