Discussion topic: Wifi
Message posted on 26 Sep 2025 12:18 PM
Wifi
Is it just me or is everyone having problems with sky broadband today as mine keep cutting out of some consoles 😞 I'm sick of it now
Message posted on 26 Sep 2025 12:56 PM
Re: Wifi
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
