1
This discussion topic has been answered Discussion topic: Wifi
This message was authored by: KatieElizabeth2
Wifi
Hiya it says my password is incorrect and won't connect. Have not changed password
Re: Wifi
@KatieElizabeth2
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
Re: Wifi
@KatieElizabeth2
