Discussion topic: Wifi
Message posted on 18 Sep 2025 08:13 PM
Wifi
How do I split my full fibre 500 wifi to 5g and 2.4g
Message posted on 18 Sep 2025 10:44 PM
Re: Wifi
@helenmcp If you have the white Sky Max SR213 hub you cannot, but the black SR203 it is possible, which hub do you have!
Message posted on 19 Sep 2025 10:43 AM
Re: Wifi
I have the white one
Message posted on 19 Sep 2025 10:45 AM - last edited: 19 Sep 2025 10:51 AM
Re: Wifi
@helenmcp Then you will not be able to split the wireless wi-fi ssid with the sky Max white hub that you have! Is there a particular problem with a device that is causing issues for you, most recent devices work fairly well with the single ssid operation, sometimes a little bit harder to get them connected, but you may be having an issue if using the WPA3-T security mode, and worth trying to drop it back to WPA2-PSK and you do have to do that with the app. Linked below if you need that!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Message posted on 19 Sep 2025 11:17 AM
Re: Wifi
It's my ring doorbell it's not working the way it should it takes a few seconds to go off after someone comes to the door and I'm sure it's something to do with the WiFi signal
Message posted on 19 Sep 2025 12:19 PM - last edited: 19 Sep 2025 12:22 PM
Re: Wifi
@helenmcp The ring app, have a look at the device settings and then the RSSI value, got mine running at -42db but do have a powerline down at the area to ensure a good wireless wi-fi to the doorbell, found the original values up in the high -68db just did not cut it so made better wi-fi at the area! Never paid much attention to the time it takes for the picture to show up but pretty sure it is not instant, and i am not using the ring chime, wired it direct on my orignal doorbell chime to ring and power the battery!
Message posted on 19 Sep 2025 12:21 PM
Re: Wifi
Thank you il give this a try and let you know if it works thanks forcall
your help
