Discussion topic: WiFi in the garden?
Message posted on 18 Sep 2025 09:07 PM
WiFi in the garden?
I need to extend the WiFi into my garden so I can connect a security camera. What's the best solution as I've tried a tp link av600 and it was ok but keeps losing connection.
Message posted on 18 Sep 2025 11:02 PM
Re: WiFi in the garden?
@united2468 With the AV600 did you have the units directly connected to power sockets, and NOT using extension cords, with powerline distance matters with overall speed but should be fine connecting a camera to it, use the WPA4220 myself and works fine!
Message posted on 19 Sep 2025 11:19 AM
One of the connectors is plugged in to my router, the other is connecting to that through WiFi. It might be the camera isn't good enough as I'm standing in my garden and my phone WiFi signal is full!
Message posted on 19 Sep 2025 12:14 PM
@united2468 Can be, got one off the WPA's out in tha garage to cover the garden area all be it at lower speeds, did go into the settings for the WPA and turned the wireless signal up to max power it does have three settings, low,middle,high you get to them on the wireless section and advanced!
