Discussion topic: Wifi
This message was authored by: Jules126
Wifi
WiFi will not connect every day I have this issue
Re: Wifi
@Jules126
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
