Discussion topic: Wifi
This message was authored by: Ashleigh53
Wifi
Won't work
Re: Wifi
@Ashleigh53 wrote:
Won't work
@Ashleigh53
If your broadband  isn't working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
