Discussion topic: Wifi
This message was authored by: Bridget-
Wifi
My wifi is disconnected
Re: Wifi
@Bridget- Was it something that you did to turn the wireless wi-fi off so you no longer see it!
Avatar for Bridget-
Re: Wifi
My router box is displaying 2 green and 1 amber light , but when i checked wifi on
MY sky app is says all should be working correctly
Re: Wifi
@Bridget- If it is the Internet light that is amber, then you will have a wi-fi connection on the device but you will have no Internet Broadband connection.
If you try to run the service checker link and see what happens, no joy with that then run the diagnostic service, and both need to be done over a mobile data connection as your broadband is down. links are below. The final link is all about the sky hubs.
Try running the line test here to see if any faults are found:
