Discussion topic: Wifi
Message posted on 19 Jul 2025 02:07 PM
Wifi
Message posted on 19 Jul 2025 03:48 PM
Re: Wifi
@Kieramack1622
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
