Discussion topic: Full Fibre 500 only showing 40.2Mb/s?
Message posted on 19 Jul 2025 12:33 PM
Message posted on 19 Jul 2025 02:24 PM
Re: Full Fibre 500 only showing 40.2Mb/s?
I would give sky a call about this
Message posted on 19 Jul 2025 02:31 PM - last edited: 19 Jul 2025 02:36 PM
@Brandini Have you actually had the Fibre upgrade installed yet, as that still looks like a connection to a fttc copper cable connected hub if indeed that is what you have!
Also run the service checker but watch closely on the start up to see that the information on screen shows your HOME address, it's very quick so you do need to watch. Details about your connection should also match the serial number of your hub!
Message posted on 19 Jul 2025 03:15 PM
Do you have an optical network terminal box fitted in your home like this?
Message posted on 19 Jul 2025 03:25 PM
If you have an optical network terminal box then you have full fibre broadband to the property and i would call sky about your problem, I have had full fibre broadband to the property since January last year gigafast and have never had any problems, not even during the storms
Message posted on 19 Jul 2025 03:29 PM
Yes we have the box fitted outside, and the box fitted inside. When using 3rd party broadband testing sites such as fast.com, it shows speeds of 450mb+. So the internet speed is all good, however Sky's service checker still shows the old broadband speeds. Guessing it is a visual glitch as our speeds have been near 500mbps since it got installed
Message posted on 19 Jul 2025 03:31 PM
I think it is just a visual glitch as we have speeds of close to 500mbps when using 3rd party broadband speed testers. But you know what Sky are like, if there is a problem with the speeds then they want you to use their service checker and not 3rd party ones, even though the 3rd party ones are right and their one is wrong 😂
Message posted on 19 Jul 2025 03:32 PM
That can take a while to change, you could try uninstalling the my sky app and reinstalling it to see if that helps otherwise just keep an eye on it
Hope this helps you
Message posted on 19 Jul 2025 03:33 PM - last edited: 19 Jul 2025 04:00 PM
@Brandini Yes you should try to get it fixed, may stop you in the future getting an Engineer visit should to ever need one!
