Discussion topic: Wifi
This message was authored by: Helenhh2
Wifi
Been a storm saying my work isn't working but it isn't !! The orange light is on
Re: Wifi
@Helenhh2
Your post doesn't make sense. Did you mean "Been a storm saying my wifi is working but it isn't "?
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
