5
This discussion topic has been answered Discussion topic: Sky fiber max keeps loosing connection.
This message was authored by: Jordan_Gaskell
My new WiFi keeps dropping here and there on many of my devices or they go to data on their own saying it's far more stable. The PC only the room opposite which has been fully checked by a professional can only get 2 bars from it and is dropping every 15 minutes pretty much. Its madness. Please advice
Avatar for Jordan_Gaskell
This message was authored by: Jordan_Gaskell Answer
Re: Sky fiber max keeps loosing connection.
This has all been done already. I have a sky max router and 300 fiber and it's shocking bad. I has sky 75 fiber before and was much  better
This message was authored by: Gavswife
Mine is the same getting fed up !!!!
@Jordan_Gaskell What did the professional advise you to do!
Unplug it and plug it back in to restart it or repositon it. Neither worked
@Jordan_Gaskell You will need to say now, what kind off service that you have from sky, and which hub that you are using!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
