Discussion topic: Wifi
This message was authored by: JS+1995
Wifi
Wifi dropping on and off
Re: Wifi
@JS+1995
Broadband or wi-fi? Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
