Discussion topic: Wifi
Message posted on 25 May 2025 01:18 PM
Wifi
Every time I switch Netflix off my WiFi goes off
Message posted on 25 May 2025 01:37 PM
Re: Wifi
Do you other devices work on Wifi when you close Netflix, I presume they do ?
Message posted on 25 May 2025 01:41 PM
Re: Wifi
No nothing works and it is still out, turned it off and off again but nothing happens.
Message posted on 25 May 2025 01:48 PM
Re: Wifi
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
