Discussion topic: Wifi
This message was authored by: Lauren199121
Wifi
Wifi keeps not working in my bedroom, works sometimes but not others
Re: Wifi
@Lauren199121  Do you have Sky broadband Max as your broadband  package? What colour is your router, blck or white?
Avatar for Lauren199121
Re: Wifi
Hi,
My router is black ☺️
Thanks for getting back to me.
Lauren
Re: Wifi
@Lauren199121  Is it strong in other rooms or is it weak around all of the property?
Re: Wifi
Sometimes it works fine in all the rooms, other times it buffers a lot. I have had someone out previously to look at an issue with the connection from outside my house too.
Re: Wifi
@Lauren199121  Where is the router kept in the property and is it out in the open?
