Discussion topic: Wifi
Message posted on 26 Feb 2025 05:30 PM
Wifi
Message posted on 26 Feb 2025 05:45 PM
Re: Wifi
@Mackenzie116
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 26 Feb 2025 05:58 PM
Re: Wifi
I have done all the links iam.paying 120 a month and this is not acceptable a technicine has been out already and stoll havi g problems iam thinking of getting sky out completely
Message posted on 26 Feb 2025 06:01 PM
Re: Wifi
If you move to another ISP using the Openreach infrastructure the problem will just move with you.
Message posted on 26 Feb 2025 06:02 PM
Re: Wifi
Can u or can u not fix the problem.
Message posted on 26 Feb 2025 06:04 PM
Re: Wifi
Nope. I'm a customer just like you.
Message posted on 26 Feb 2025 06:26 PM
Re: Wifi
Sorry I thought u where customer service
Message posted on 26 Feb 2025 06:31 PM
Re: Wifi
No problem.
