Discussion topic: Wifi
Message posted on 16 Feb 2025 01:51 AM
Wifi
WiFi keeps on dropping out
Message posted on 16 Feb 2025 05:37 AM
Re: Wifi
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up in the morning use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
