Discussion topic: Wifi
Message posted on 11 Feb 2025 12:18 PM
Wifi
Message posted on 11 Feb 2025 12:22 PM
Re: Wifi
@Amber1502
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
