Discussion topic: Wifi
This message was authored by: Heaton24
Wifi
I've tested our WiFi and broadband and it's saying everything is fine however we have no Internet as there is no green light on the box it's flashing orange
Re: Wifi
@Heaton24
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
