Discussion topic: Wifi
Message posted on 05 Feb 2025 09:48 AM
Wifi
My WiFi won't work
Message posted on 05 Feb 2025 10:57 AM
Re: Wifi
Not a lot to go on there but if you haven’t done it already use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
