Discussion topic: Wifi
Message posted on 29 Jan 2025 10:15 PM
Wifi
The wifi internet is not working since last 3 days can u send anyone to fix it please?
Message posted on 30 Jan 2025 06:32 AM
Re: Wifi
@WIFI11
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
