Discussion topic: Wifi
This message was authored by: Carol19581
Message posted on 26 Jul 2024 12:26 PM
Wifi
WiFi keeps going down. I am working from home I need the WiFi
Find out more
Message posted on 26 Jul 2024 12:31 PM
Re: Wifi
@Carol19581 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Please run the service checker using the link above, if it comes back all fine please click on the broadband to get an updated check on your broadband.
