Discussion topic: Apps wont make secure connection.
This message was authored by: Brollman
I'm new to Sky broadband (3 months) and thunk there might be something wrong with my router. When my phone connects to wifi and I open some apps, it won't make a connection or it takes an inordinate amount of time. When I disconnect and use data, it connects straight away. I then reconnect to the wifi and it will then sometimes make the connection.
I have turned shield off entirely, so it's not this, and have all the factory default settings in place. The only change I have made is to hide the SSID.
This is infuriating! Is this a problem with the router that can be remedied by getting a new one?
Re: Apps wont make secure connection.
Hi @Brollman
Do you have Apple devices? If so try disabling iCloud relay
I am NOT a Sky Employee
Avatar for Brollman
Hi James,
Thanks for your response. No, I don't have any apple devices.
@Brollman
Could you try with an ethernet connected device if possible?
Avatar for Brollman
All the apps are on my phone, I don't have a USB C to ethernet connector.
