Discussion topic: Wifi
This message was authored by: adamleigh75
Wifi
My WiFi isn't working even though I've done the test in the sky website and it says "all working fine" and yet strangely it isn't working...
Re: Wifi
@adamleigh75  Can you follow the link below and pick the router you have to see if the lights you are seeing is causing a fault on your broadband connection.
