Discussion topic: Wifi
This message was authored by: Biggerard
Wifi
My wifi keeps Buffing and it was the same this time last nite aswell
Re: Wifi
@Biggerard itsxworth running the connection test in the My Sky app and allow it to test the Wifi connection to your devices. That may tell you whst is wrong. It is worth simply rebooting you hub as thst will make it check for the least congested wifi channel as intereference from neighbouring networks is a common problem.
