Discussion topic: My bordband not working keep droping and flashing orange
This message was authored by: Mckale+666
My inter net keeps droping done all of above box keeps flashing orange
Re: My bordband not working keep droping and flashing orange
@Mckale+666 if the connection is still down this mornning run the Connection test in the My Sky app over a mobile connection as thst can tell you if there is a known fault affecting your line. If there isnt call Skybto report the fault but it is likely to be some days until Openreach can check your line.
