Discussion topic: Wifi wont work
This message was authored by: Lorna3255
Wifi wont work
WiFi router has 2 amber lights. Will not reset no matter what I do. Checked all the cables and everything's fine, but still doesn't work. Need an engineer
Re: Wifi wont work
@Lorna3255  Resetting your hub won;t work if the fault is external.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
