Discussion topic: Wifi strength
This message was authored by: Darren1992_
Wifi strength
My wifi signal is struggling to connect to my ring doorbell it says the signal is too weak, my router is roughly 14 feet away from my door how is this possible when i paid for the fastest broadband.
Re: Wifi strength
@Darren1992_
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
