Discussion topic: Wifi still not working
This message was authored by: Petworth
Hi, I’m getting in touch again because my WiFi is still not working properly, despite running all the recommended checks. Every test I do says the connection is fine, but in reality it’s unusable. I can’t load basic webpages, streaming is impossible, and I can’t hold a Teams call without constant dropouts.
I previously called about this issue and was given a one-month refund, but the problem has continued with no improvement. I’m really disappointed, especially as Sky advertises a strong WiFi guarantee, which I’m clearly not receiving.
Please can you look into this urgently, as the service is not meeting the guaranteed standard. I would also like to request another refund for the period the service has not been working properly.
Thank you, and I’d appreciate getting this resolved as soon as possible.
Re: Wifi still not working
@Petworth
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@Petworth
Sorry but you are not talking to Sky via here as we are customers here like you.
Are all the lights showing as being lit on the hub ?
