Discussion topic: No WiFi
Message posted on 17 Nov 2025 01:31 PM
No WiFi
No WiFi connection have done all the advice of plugging etc but nothing. I can see other have the same issue please sort this out
Message posted on 17 Nov 2025 01:48 PM
Re: No WiFi
@London13468
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
