Discussion topic: Wifi speed fiber question
Message posted on 21 Feb 2026 11:11 AM
Message posted on 21 Feb 2026 11:17 AM - last edited: 21 Feb 2026 11:18 AM
Re: Wifi speed fiber question
@Brianbletchley wrote:
How can I check if my line can handle sky fiber and if I will need an engineering to come out ??
An existing copper line by definition cannot 'handle' FTTP at all.
Also when or if I upgrade my broadband will that boost my WiFi as I have black spots at the moment?Only if the WiFi Max subscription supplement is added to the account.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 21 Feb 2026 12:23 PM
@Brianbletchley You can also use the sky checker below in case you happen to be in a CF CityFibre area.
https://www.sky.com/broadband/full-fibre-broadband
