Discussion topic: Wifi signal
Message posted on 23 May 2024 09:37 AM
Wifi signal
My wifi connection is poor. I have bought a wifi extender for my shed but because my sky wifi is poor that is now not working? I have reset and turned it off but it still says poor signal.
Message posted on 23 May 2024 09:47 AM
Re: Wifi signal
An 'extender' located in the shed itself isn't going to help if the shed is out of wireless coverage anyway.
Typically the only viable location for such a device would be inside the main property but as close as possible to the external building, and preferably with line-of-sight through a window rather than a wall.
Message posted on 23 May 2024 10:34 AM
Re: Wifi signal
Thank you for this, the extender says you can be 300m away from the box, it has been working but I think my ski signal isn't great which is then making the rest not work.
Message posted on 23 May 2024 12:12 PM
Re: Wifi signal
What extender did you get? I would be very surprised if it says you can be 300m away. I suspect what it means is that it can provide coverage up to '300m' but not actually connect back to your main router 300m away.
