8
This discussion topic has been answered Discussion topic: Wifi signal not connecting and dropping
This message was authored by: Michael_d
Wifi signal to mobile phone poor even with wifi signal .turn off wifi and just have mobile data and it connects straight away.
Avatar for Michael_d
This message was authored by: Michael_d Answer
Re: Wifi signal not connecting and dropping
Hi yes.even when right next to hub its not downloading. Change to mobile data and it downloads right away ?.
@Michael_d
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
@Michael_d Just the mobile device that has the poor wifi connection to the sky Hub?
@Michael_d You are not making it easy, is the mobile device connecting to the wireless wifi ssid of the sky hub? What sky Hub are you using if it is connecting, the fact that it does not download is that everything you try etc!
Easy test, switch the Mobile data off on the phone, see if it will latch onto the sky hub wireless wifi signal and work if and when close by the hub?
Yes it connects to the wifi ok..but when u to and download something it wont download. Its a maxi hub.am connected to mobile data at the moment .its quicker than the wifi that can't be right ?.
@Michael_d Check the sky max hub with the MySky app and advanced settings, see what the wireless securities is at, WPA3-T or WPA2-PSK,
i had a samsung A54 would drop back to 17/70Mb/s on a FF500 feed, was just a poor wireless wifi signal wifi off/on again back to the full 500/70 so anything can happen at anytime! Just trying to pin whatever is going on especially if you say it is ONLY that one device with the issue!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
I will try.thanks.mike.
This message was authored by: cessie
Turning off WiFi on your phone doesn't it affect the  internet on you phone
