Discussion topic: Wifi signal drops
This message was authored by: Ellenlb95--
Wifi signal drops
When testing wifi signal is good and says I'm getting the speeds , then the wifi will loose signal to all devices, we cannot connect our upstairs TV , the sky glass TV in the living room regularly looses connection. I'm currently sat with an iPad that cannot even find the wifi to connect to.
Re: Wifi signal drops
@Ellenlb95--
It could be you have a poor signal in certain rooms as this is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
