Discussion topic: Router issue
Message posted on 11 Jun 2026 07:01 PM
Router issue
Message posted on 11 Jun 2026 07:34 PM
Re: Router issue
@Natashabill123 wrote:
The speed from the router is only 72mps
The important figure is the speed to the router, what does the diagnostic link below tell you?
Have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
