Discussion topic: Wifi problem
Message posted on 19 Nov 2025 03:42 AM
Wifi problem
Message posted on 19 Nov 2025 04:51 AM - last edited: 19 Nov 2025 04:59 AM
Re: Wifi problem
@Rose+1972
Your duplicate thread has been removed as you already have this one.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach, Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
