Discussion topic: Wifi Has Gone Down In Telford
This message was authored by: NicolaKS
There appears to be a wifi outage here in Telford around the Muxton, Donnington and The Humbers area's. At 1.15pm
This message was authored by: Wolves_Hero
Re: Wifi Has Gone Down In Telford
Same here Wolverhampton twice time went down. I switch to 5G hotspot WiFi from mobile to PC lucky only 26Gb data left.
@NicolaKS @Wolves_Hero
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach, Hopefully it'll be back up and running before 7am.
If it's not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
