Discussion topic: Wifi pratting around
Message posted on 22 Aug 2025 04:46 PM
Here we go again!! I thought we saw the end of this. Once again the service checker swears everything is fine but it isn't
Message posted on 22 Aug 2025 04:55 PM
Re: Wifi pratting around
@Veda
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 22 Aug 2025 05:56 PM
There are currently issues in Birmingham, Shropshire and parts of Worcestershire if you're in that area.
