Discussion topic: No wifi
This message was authored by: Lauralamb1
No wifi
My wifi isnt working. Ive reset the box 3 times and still nothing.
Re: No wifi
@Lauralamb1
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Re: No wifi
@Lauralamb1
There are currently issues in Birmingham, Shropshire and parts of Worcestershire if you're in that area.
