Discussion topic: Wifi poor in the house
Message posted on 12 Dec 2025 09:15 AM
Wifi signal booster pod doesn't appear to make any difference to my wifi signal and I have completely dead spots in the house. Not currently able to watch tv in the bedrooms and limited singal in some of the rooms. Is there anything I can do to improve the wifi signal? f
Message posted on 12 Dec 2025 09:23 AM
Re: Wifi poor in the house
@tvmarie12 first ensure the hub is in the best possible position which is out in the open on a surface above obstructions like radiators etc. if the cable to the connection is too short you can buy a longer one quite easily.
Next ensure the extender pod has a good connection to the hub so -lace it no morecthan halfway from where you need the boost. If after that you still hsve issues call Sky and they will arrange for an engineer to visit to test your network. The engineer cannagree to you having up to 2 more pods as part of the WiFi Max package.
