Discussion topic: Wifi poor connection
Message posted on 23 Sep 2026 12:30 PM
Message posted on 23 Sep 2026 12:41 PM
Re: Wifi poor connection
@AMartin121 wrote:
I'm unable to hold a Teams call today as the wifi is poor. This is not practical as I work from home
We're only other customers here, like yourself.
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
